FX5 to Panelview 800 modbus TCP/IP
melcsa
Oct 2013
monterrey
We have to connect a Mitsubishi FX5 PLC using Modbus TCP/IP to a Panelview Plus 800. We have communicate integers, bits and real numbers, but we have not been able to communicate strings. Could somebody please tell me the sintaxis of the string variables in the Panelview to use with the FX5
We have tried 40201.2H , 40201.32L , H40201.32 and 40201/32
Not sure about the PV800 but something comes to mind about strings via modbus to a scada system I was involved some years ago
To address a string starting at 40200 with a length of 32 bytes and Hi-Lo byte order, 40200.32H
To address a string starting at 40200 with a length of 62 bytes and Lo-Hi byte order, 40200.62L, but it does appear you have already tried some of these combinations, so I can only assume the PV must have some kind of different format.
PLC: Fx5u CPU As Per manual High Speed Input Module can add from Navigation window  [Parameter]  [Module Information]  Right-click  [Add New...
106
Good morning, I have had a machine stopped for some time, my servo works in manual mode, but it does not work in automatic mode. My equipment...
81
Bom dia, Estou com uma máquina parada algum tempo, meu servo funciona em modo manual, porém não funciona em automático. Meu equipamento e...
67
Hello, I'm currently working on a project where I need to read values off my 0-3kg Strain Gauge and display them on my HMI display. I've...
1,843
I’m fairly new to PLC programming. This is our first machine that uses an FX5 PLC rather than an FX3, and therefore GX Works3 instead of GX...
1,258
