Gantry milling machine interpolation
gica2002
Mar 2003
Hello everybody,
I'm in trouble. Any idea would be very appreciated.
Description:
I'm trying to setup a gantry equipped with Siemens Sinumerik 840D and 2 working channels (NC with 2 channels).
The purpose is to machine 2 different workpieces in the same time (see attached files). We use identical tools for machining, tool diameters between 40 and 63 mm and machining must be done in X+ direction.
Well, manual calculation of the second channel feedrate, based on the first one is not a helping idea.
I will provide more details to anyone interested.
Thanks,
gica2002
I downloaded your zip file and took a look at your application. If I understand you correctly, the machine actually has 5 individual axes (X, Y1, Y2, Z1, and Z2). Of these 5 axes, at least 3 of them need to be coordinated (X, Y1, and Y2). You did not indicate that the two Z axes needed to be coordinated as well, so I will assume they do not.
Since your typical CNC controller appropriately adjusts the feedrate of each axis in a coordinated move, the controller should be able to do the job all by itself. Remember that the controller's goal is to finish all axis movements simultaneously. This means that it will adjust all axes feedrates with respect to the slowest axis in the coordinated move.
If you use a single 5 axis controller and assign each of these axes as a unique axis with the first three assigned as "coordinated" (X=X, Y=Y1, and Z=Y2), you should be able to write your G-code in the form G01 Xxx Yyy Zzz Fff and get the desired results.
Hope this helps.
Steve
Yep. Your right. I missed that Z movement.
If I am not mistaken, a 4-axis coordinated move on a 5-axis controller would still do the trick in this case. As long as each axis move is called out on the same line of G-code, I can't see where there would be a problem.
Steve
Hi Steve, Rick,
Thank you for your efforts.
Yes, I think I'll need a 4 axis interpolation feature.
Take a look at this picture, another case.
For the first case it was easier to use a G01 or G00, for linear movement, but what about this one?
<IMG src="http://colony.host.sk/images/workpiece2.GIF">
Thanks,
gica2002
You can't in one pass. You will have to do each individually. After you circle interpolate the top radius you will have no x component, the milling can't continue on the bottom part.
Is this a class?
Hi, I have a project where one of the modules is a gantry type structure with 2 servo motor, one from each side of the gantry. The transmission...
1,724
I plan to use a profile sensor or something like that measure the distances between the gantry’s Z height and the Z height of the conveyor...
19
10,710
Hi, I am doing testing for a Gantry motion and its Power cable reel which is wound, unwound on a wheel. I have connected VFD for both motions...
1,037
Hi, We are trying Hoist synchronization for 4 hoists which has same motor, gearbox and drive. In PLC(Schneider) there is a FB for synchronization...
2,553
Hi, I am a senior mechanical engineering student working on a design project and I have to control a 3-axis gantry system powered by Sanyo Denki...
20
4,569
