Ken Roach
kvogel and baldone, and as always Mr. Nachtwey, have given solid advice about gantry control using gearing features of the motion control system.
Every multi-axis controller includes a gearing function of one type or another. Sophisticated ones have features that are specifically meant for the control of parallel axes. Check out, for example, the automatic skew elimination feature of the Delta Tau PMAC at 1:20 in this YouTube video [link].
With ControlLogix integrated motion, the Motion Axis Gear (MAG) instruction is the basic feature used to control parallel axes. You can gear one axis to the other, or you can gear both of them to a virtual axis.
Initial alignment of machine tools is a field of endeavor all its own; most gantries use hard stops and at least a few points located by a laser tracker to determine the home position of each servo axis.
I just got back from doing some work on a sixty-foot gantry system using Kinetix 6000 amplifiers on SERCOS with ControlLogix 1756-L61 controllers, and the MAG instruction is the basic function we rely on to keep the two sides of the gantry running together.
