GE 90/30 Battery Issue
biil2769
Dec 2004
wisconsin
I have a 90/30 that keeps draining the battery and then at next start up there's no program. This has happened 3x's so far.
The machine sits for long periods with the power off.
The last battery was replaced in January 2015 and when I went to start it up last week the battery was dead and no program.
I did try a new power supply this time to try that but the length of time in between runs makes it harder to find cause of the issue.
Any ideas of what to replace would be appreciated.
this is the original hardware config.
IC693CPU350 CPU
IC693CMM311 COMMUNICATION
IC693MDL646 NEG INPUT
IC693MDL740 OUTPUT
IC693MDL740 OUTPUT
IC693MDL740 OUTPUT
With that CPU, if all you need to keep is the Logic and hardware configuration you can tell the CPU to "Copy from PROM" (Flash) on power up in the CPU's 'Hardware Configuration' then burn that to flash on downloading and forget the battery.
Or there are new battery types now that you could use. Contact your rep or distributor for those options or search the GEIP Support site.
hi i have some issue with battery in the electric smart meter the battery dies after 2 month they most work 5 year you can see the pic in the...
2,559
i just want to inquire how to resolve my problem. Problem: we have a battery fault on a CPU with a 1756 BA2 battery. we only have 1756BA1...
1,510
I'm ashamed to admit this but I've never had to replace a battery in a SLC. Some how been able to skip that task in all my years. So yesterday...
261
Hi to all. On our Siemens PLC power supply, the battery light is showing amber. If we do not immediately change the batteries, will we lose the...
142
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
257
