GE 90-30 LM90 software availability
ESBrian
Nov 2005
Vermont
Hello,
one of our clients' GE 90-30 PLCs has lost its program - we deal mostly with AB hardware, so we don't have any old GE programming software kicking around. The original integrator has provided us with a backup of the logic from 1995.
Is the LM90 software available anywhere anymore? Every link I've come across is dead, and our GE distributor no longer has access to it either.
I have a Windows XP VM on a Windows 7 PC and an old DOS 6.22 laptop that still runs.
Thanks,
Brian
In 2019, Emerson acquired the GE Intelligent Platforms business, creating Emerson Machine Automation Solutions. This (attachment) is what we were using (Proficy ME) prior to Windows 10. For the W10 version, we had to deal with Emerson, not GE as before. My GE knowledge is not great, so I don't know if the newer software will open and convert code created in LogicMaster. We were using VersaPro in between LM and Proficy. Good luck!
The current software from Emerson has the ability to import a Logicmaster file.
Was the backup in the form of several files with file extensions like .pka, .pkc, .pko? If so those are the backup files and you do need Logicmaster to restore them to a format that Machine Edition can import.
Logicmaster will not be able to communicate with the PLC when running under a 64-bit operating system.
Send me a PM with your email address. I can send you Logicmaster, or I can restore from the .pk* files and send you a project folder that can be imported into Machine Edition.
We have a customer that has 6 machines running GE Series 90-30 PLCs. In order to support them, they bought a used Dell Full size desktop PC with...
1,246
Hi Every one, I tried to upload from ge 90-30 plc using versapro software, so that i may migrate program to machine edition. when i try to...
1,579
can anyone can gave a link or can upload software of ge fanuc lm90 software? this will help me a lot to troubleshoot my ongoing task..thanks
3,007
hello, we have a packaging maching which run by GE-90-30 plc, and the software is LM90. the maching was stopped few weeks ago & the cpu run light...
7,680
Please tell me where I may purchase a copy of GE Fanuc LM90-30 software. Thanks!
17,698
