GE 90-30, ME 9.5, Going online to troubleshoot
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
Another customer called today to help them troubleshoot thier Ferry Rotomold machine. This is good because it's giving me an opportunity to build my Profacy ME skills. I still find it hard to get the answers to some basic questions, though. And with the holiday week, tech support was under-staffed today... there was nobody there who could field a 90-30 question.
Easy question for those familiar.... the red X over the target name doesn't go away after uploading the program to the laptop. I believe that is because the PC version does not match the PLC program. I'm trying to use the software to troubleshoot the program, so I need a real-time connection that shows me the state of the bits. Is there a way to overcome this? Is this a case where I need the old VersaPro software? ....I'm just trying to remember the things I've learned so far.
BTW.... CPU 363
Thinking of follow-up questions in advance.... If I do need VersaPro, I'm guessing the only way (if any) is to contact my GE distributor? (Powermation in MPLS/St Paul) Is VersaPro available, even though it's not supported?
If the program was created with either VersaPro or Logicmaster you will need to first upload from the PLC to Proficy machine Edition and then download from Machine Edition to the PLC to get to a "Logic Equal" state. With a 90-30 you will not get names, nicknames or rung comments when you pull the program from the PLC.
Ugh! That's what I thought you'd say. That scares the heck out of me! I'm not sure what I'd do if the machine didn't work after doing that... for whatever reason.
What's your level of confidence in that scenario? What would you do? If I found the old software, would that help? Would you look for the old software, or validate and download using ME?
In my case I have all three software packages so I could try VersaPro if I couldn't get to Logic Equal with PME.
Does the customer have a backup CPU? If so pull the program from the PLC on the machine and download it to a backup PLC. That should allow you to get to Logic Equal and give you confidence that you have successfully uploaded a program.
Powermation has been a distributor for a long time. They should be able to find a copy of VersaPro for you. If you're on good terms with them they may even be willing to have their automation specialist help you with your customer.
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
404
Good Afternoon. I am having a problem going online with S7-400. Attached is the error that I am getting. I have looked at the help file but the...
1,814
The machine is running production. When trying to go online with the laptop the whole machine looses communication and faults out. Drives, HMI...
1,963
Hi I have a machine that has 1500 cpu program is v15:1 I have the program from the Oem and the tia portal software v15.1 ? I have set the laptop...
1,887
Hello Everyone, I'm a pretty green PLC tech and I need help logging on to some SLC 5/04 PLCs. I have a 1747-UIC and 1747-CP3 cables and I'm using...
6,978
