GE Fanuc 90-30 Basic (stupid) Question
That explains your communications problem. For some reason, Logicmaster is unable to load the serial port communications driver. That could be because it can't find the file or because it can't find enough available memory to to load it into.
First, make sure the file c:\winnt\system32\snpwnt30.dll is present on your computer. If it isn't, try reinstalling Logicmaster. If it's there, go back to the initial Logicmaster screen and hit F9 (setup) and then F4 (comm) and make sure you have selected "Automatic" in the "Driver memory area" field.
Hello, I have Fanuc 90-30 with cpu-331 and ic693acc300c switch input test module and ic693mdl740c 12/24 output control module. Entered simple...
17
6,974
I have a simple two rung program loaded. Uses IC693ACC300C switch input simulator and IC693MDL740C output module (12/24 VDC pos logic). The...
22
9,287
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
115
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
114
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
106
