GE Fanuc 90-30 series
Biff383
Nov 2006
Byron Center MI
I have a Fanuc controller that dosent seem to have any signal going to the output card. There seems to be power in all the right places,however I would expect at least the offline bit to be lit and it is not.
Also, does anyone know what software I need for this beast?
What controller do you have?
Do you have PWR OK RUN Green lights on the power supply? Proficy Machine Edition is the Software used for the GE Fanuc 90-30
Give me a call, I'm in your back yard. (or PM me for contact info)
The GEIP tech support web site will answer a lot of your general questions. www.ge-ip.com/support
Has anyone worked with on of these PLC's? If so, how do I connect to one? What software do I need? What cable do I need? I'm looking online...
685
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,152
Dear Experts I need to connect to this CPU 374 It seems it is a GE Fanuc PLC I want to know if I will require any specefic cable - from the...
1,870
Is there any way to make a connection directly between a GE Fanuc 90-30 and a Mitsubishi FX Series PLC? If there is no means to connect directly...
21
4,302
I have a Fanuc Robot F-200iB Series 9, 6 Axis and it is running on R-J3iB controller and the controller is configured to Mitsubishi PLC Q06HCPU...
1,943
