GE Fanuc 9030 optical communication
Apr 2003
25
Hello,
We have some GE Fanuc PLCs 9030 series with CPU 374. I want to know if this type of PLC has a communication card with fiber optic connection. If not,please advise how to connect the PLC to fiber optic media.
Thanks,
Eduardo
The CPU374 has a two port 10/100 unmanaged switch with standard rj-45 connections built into it. You can use any compatable fiber router or modem to connect to it.
Hello everyone, We are trying to upgrade a GE FANUC 9030 PLC, but we are having trouble extracting the program from it. LogicMaster90 is able...
1,315
Hello, I Have a GE Fanuc RX3i that I migrated that Has a IC695CHS012 for the Main Rack and 4 IC693CHS392 Expansion Less than 50Ft. I ran across...
1,809
I am converting our Boiler project to a RX3i. Looking at some of the registers for the HMI I see 100r. It is labeled B_1_GPM (Boiler 1 Gallons Per...
2,676
So we currently have a CPU 374+ running a sort of feed bin process. We've had the PLC installed since 2008, with really no problems. I am...
2,390
Good Afternoon I have a few questions regarding Ge Fanuc 9030 series and Modbus. I have a Ge Fanuc 9030 for test Purposes. The Rack Is...
6,990
