ge fanuc card
In GE Fanuc part numbers, the last alpha character is the revision level. If you order an IC693MDL646 from your distributor, you will get whatever revision level they have available.
Occasionally, there are issues with an old revision level of a module not being compatible with a newer revision level of CPU. GE Fanuc publishes (at tleast tey used to) a compatibility chart that covers those details. In the specific case listed, there are unlikely to be any compatibility issues since the moduel in question is a simple DC input card with a fast filter time.
I wouldn't call it a disaster. The cases where there are issues are relatively rare. Where they occur, they are generally in "smart" modules like network interfaces. I'm not aware of any compatibility issues with discrete I/O modules.
A revision letter hear could simply mean that GE Fanuc is getting a component from a different vendor.
Hi, I have gefanuc plc system 90-30 series and proficy m/c edition 5.3.My one NIU card showing LED status are BUS B and IO enable in amber...
1,493
Hey Everyone, I'm in a bind here at my job we have a GE FANUC Series 90-30 PLC with a embedded CPU in the base plate with 5 I/O Slots our...
33
10,804
Forgive me if my question is repetitive or verbage is off, learning this all as I go. I have a question what type of card would I need to accept a...
3,424
hi, everybody I have a ge fanuc 90-30 base 10 slot ic693apu302, it is connected to the plc via a 25 pin cable connecting the plc to the pc through...
4,720
J
Hi, Would GE Fanuc AI cards (current) would work with self-powered loop? Thanks JC
3,880
