GE Fanuc Ethernet Remote IO Question
jimbo3123
Sep 2003
Detroit Area
550
Does anyone here have experience with Ethernet Remote IO with GE Fanuc PLCs?
Specifically, I'm trying to set up a PAC Systems PLC with VersaMax remote racks over ethernet. The remote racks have IC200EBI001 ethernet modules.
I have a test setup here, and it's communicating. However, the fault light on the VersaMax is lit, and I can't figure out what I have to do to make it go out.
There are a lot of things to configure under produced and consumed exchanges to make the ethernet communications work. I think I have it set up right (data does transfer to/from the remote rack).
If someone has a working program with similar comms, I'd like to check it out to verify my settings.
Did you remember to add the 2 bytes for status that the VersaMax EGD I/Q needs?
I am willing to look at your configuration and see if I can spot the problem.
rbartels at glasupply dot com
Thanks, I think I got it though.
I had the bytes there, and I was able to translate them into error codes and clear the faults. I tracked the problem down to an analog output card. I hadn't set up any configuration data to it, so I just removed the card for the time being, and my fault cleared. I'll look into the proper configuration words and hopefully get that set up later.
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
106
Just wondering if anyone has had any experience with using a Fanuc Robot (R30iB) to a Logix 5000 over Ethernet/IP using Safety. I have some...
1,595
Hello, I have a Fanuc 90-30 plc`s in some equipment. I would like to make them remote diagnostics. I have the programs for equipment and want to...
939
I want to be able to read and show 5 latest Alarm messages from the Fanuc R30-iB robots to an Indusoft Web Studio 8.0 HMI. Does anyone have...
3,691
Good Evening , I have a Fanuc M 410i R30 iA , that is communicating with a CompactLogix L32. In the CompactLogix program there is a Robot...
3,522
