GE Fanuc serie 5 PLC - upload ladder
deedle
Jan 2010
Wisconsin
I am working on a GE FANUC series 5 PLC. The batteries went dead. They are replaced now, but no program or ladder is in PLC now. I found a cd with the ladder on it, but don't know how to load into PLC. The machine has a PC attached and C:\ got to "Logic Master 5" software. Under display program-scratch pad- no program was there. What now??
You will first need to read the program from the CD into your PC's memory and then write it to the PLC. Once you launch Logicmaster Five, go to the Load/Store/Verify menu. The program file will have a .LAD file extension.
I have Logicmaster Five software on an old DOS computer. If you need someone to walk you through the steps, I'll be in the office tomorrow. Send me a private message with your email address and I'll send you my telephone number. I'm in the Eastern time zone.
You should seriously consider replacing that Series Five with something newer. Replacement parts for it can be hard to find and will be expensive.
Hey I am not trying to make a sales pitch but I do have some Series 5 stuff back at the shop. It was retrofit in a plant because of it's age. I was given all the parts from the stock room for PLC. So if you need any parts I may be able to help you out.
Today was very good. With Steve's "Good and Fast" help, got ladder loaded. Nice job Steve, and many thanks. Still have issues with both output modules off. I suspect the PLC might have an output disable function - due to all data lost from CPU and memory module. Could this be? What else would keep the outputs from coming on?
Hello friends i want to know how can i establish an communication between Cimplicity for example 8,2 and PLC GE Fanuc serie 6 please the pinout...
2,107
Hello i have a old PLC GE Fanuc serie 6 with card communication CCM2 this PLC is connected to a HMI Panel Nematron, i want to make a new hmi scada...
28
9,276
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
37
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
123
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
116
