GE fanuc series 1 PLC
It depends on the model. Some are supported by AutomationDirect.com and others are "orphans". If ADC isn't compatible, you may want to contact your local GE Supply - they may have what you need.
Nathan,
Before running off to your AB distributor and spending thousands of $$$ and lots of time etc.....
What's toast?? the CPU.. Many Series One CPUs have a removalble program memory chip that could be installed in another CPU.
The Base?? (the weak part of the the Series One..Direct replacement bases are avaliable from www.AutomationDirect.com or you can take a look at Ebay for some good deals also.
I/O modules?? AutomationDirect has like 90% of all the I/O modules for the Series One also.
Additionally I've got a pretty good stock of DL-305/GE series One components, and may be able to help you out also.
Give more detail and you might be able to save on turnaround and $$$$.
Mike
I agree with Mike above. There are plenty of parts (for the Series 1) floating around on ebay that can be had on the cheap or new from AutomationDirect. Why reinvent the wheel by switching to a different software platform?
Ge Fanuc series one
Thanks guys for the insight. I managed to find what I needed from Automation Direct just as you suggested.
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,068
Hello Does anybody have FANUC series 90-30 PLC configuration softwate? I need it . I have a big problem, Please hepl me...
1,769
Hi guys. Im a total PLC noob. i suspect a dead 331 cpu. Unable to communicate with it using the LM90 start utility. But i could on another CPU...
2,934
Hi All, I have just started using GE PLC and wish to check for some information. I was able to connect to my 90 - 70 PLC with COM1. I would...
2,909
Hi, I have gefanuc plc system 90-30 series and proficy m/c edition 5.3.My one NIU card showing LED status are BUS B and IO enable in amber...
1,491
