GE Fanuc Series 90-20 Programming
Aabeck
Feb 2013
Detroit
1,860
I need to connect to a 90-20 PLC and have the Proficy Machine Edition software, but it doesn't support the 90-20.
I put 2 calls in to my local GE distributor but haven't received any call back about it.
Does anyone know what software is needed for the 90-20?
Has anyone worked with on of these PLC's? If so, how do I connect to one? What software do I need? What cable do I need? I'm looking online...
662
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,070
Dear Experts I need to connect to this CPU 374 It seems it is a GE Fanuc PLC I want to know if I will require any specefic cable - from the...
1,799
Is there any way to make a connection directly between a GE Fanuc 90-30 and a Mitsubishi FX Series PLC? If there is no means to connect directly...
21
4,241
I have a Fanuc Robot F-200iB Series 9, 6 Axis and it is running on R-J3iB controller and the controller is configured to Mitsubishi PLC Q06HCPU...
1,911
