GE Fanuc series one junior
Mar 2010
Milton
dose anyone have any info on a GE Fanuc Series One Junior, I have one that will only run in Hand and not in Auto I would like to go on line and see what the conditions are for Auto. I do not have the software or cabe for it... Any information on finding them would be great thanks
There is a hand help programming unit that attaches to the face of the controller. You can use that to manually write the program to paper.
You can also transfer programs with a tape recorder, and cable.
You can try PLCCenter .com or ebay for the handheld and cable.
AND..............WELCOME TO THE FORUM!
Try Here.
http://www.*********.com/automation/ge-fanuc-manuals/series-one-ic610/GEK-90503
The manual I have is GEK-90503.
I have lots of these programmers laying around. PM me if you are interested in one.
:p
Has anyone worked with on of these PLC's? If so, how do I connect to one? What software do I need? What cable do I need? I'm looking online...
665
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,087
Dear Experts I need to connect to this CPU 374 It seems it is a GE Fanuc PLC I want to know if I will require any specefic cable - from the...
1,815
Is there any way to make a connection directly between a GE Fanuc 90-30 and a Mitsubishi FX Series PLC? If there is no means to connect directly...
21
4,253
I have a Fanuc Robot F-200iB Series 9, 6 Axis and it is running on R-J3iB controller and the controller is configured to Mitsubishi PLC Q06HCPU...
1,916
