Ge i/o update through external cpu via ethernet
kakagi
Feb 2011
india
well there is two CPU of Ge IC200CPU005E the distance between two cpu is above 1 km.
now in one cpu there is analog signal coming from level transmitter and the pump is controlled by the other cpu which is situated at a distance of 1 km.
i want to stop the pump in this cpu when the level reaches high (level transmitter connected in another cpu).
we r using wireless radiolinx modem. so how can i implement this in logic?
I would start with the "Read Bytes" & "Write Bytes" commands found in the Versa Max manual:
http://www.*********.com/pdfs/gfk1503c.pdf
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
128
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
115
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
103
Hi, I have an iFIX 5.5 project (Windows 7) that needs to be updated to version 6.5 (Windows 10). iFIX communicates with the "Siemens Industrial...
181
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
493
