GE Proficy Machine Edition renaming variables
A_G
Jul 2014
MA
370
I have a GE Proficy Machine Edition v9.5 project. I have to rename about 100 variables but keep the same addresses. (The customer is getting a copy of the logic and wants these variables renamed)
What is the easiest/fastest way to do this? Is there any way to export variables to a spreadsheet, modify the names in the spreadsheet, then import them back?
Thanks in advance!
I think what you are looking for is Variables Tab then Export to CSV then make changes and Import the csv and overwrite existing variables.
Make a backup before you do this.
It is kind of tricky in doing the import. You have to pay attention to if you are changing variable name or variable address.
What Nathan said...
If you rename the variable, then when you import, you are not overwriting the existing variable.
You may get a duplicate address warning, I don't remember.
After you import the 100 tags, you may need to manually delete the old ones from the Variable table.
What Nathan said...
You can choose on import to use existing variables (over write existing addresses) or existing addresses (over write existing variables).
Make sure you pay close attention to what you pick to do in the import windows! You have to read a few times to make sure of your choice...
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
105
Hi, I am still a beginner with PLCs and I have never worked with GE PLCs before so looking for some help. I am using GE Proficy Machine Edition...
1,378
I am trying to download version 9.8 of G.E.'s proficy machine edition, does anyone have a link to a download site?
5,158
Need to learn a few more tricks in Proficy Machine Edition. I don't use it often, but one of the first things I usually do when getting into a new...
1,024
I have a GEFanuc plc 90-30 that has dumped it's program and IP. The tool in PAC for setting a temporary IP is not available. The Offline Commands...
2,024
