GE Profinet IO Connection issue
Sanjo_peter
Dec 2019
Texas
Some of our profinet IO scanners (IC200PNS001 - GSDML - V2 2GEIP - Versamax PNS - 20110210) are dropping out intermittently for 7 seconds. Other profinet scanners connected to the same controller do not have any issue. Is there anything can be done from the PLC to fix this issue?
Besides the Obvious, Make sure the latest firmware. Any cabling termination rj45 be checked for defects. 1 node or device can create a broadcast they may be knocking out the others. Is all the devices on the same network that are affected. The ones not affected on a different network or the same. Are these on a switch or daisy chain from the controller. If on a daisy chain from controller I suspect the first inline that the trouble starts to be a suspect.If that one loses power or hickup it will affect the other downstream. Are you using the PINO_DEV_COM instruction and you may be able to see any faults accruing in the fault table may tell you also.
Hi everyone, I have a Siemens PLC and a CP. I have several devices connected via profinet on the CP PN/IO port. I also connected the G-BIT...
1,276
Hello all. I have a strange situation on my hands. I have a VIPA CPU 315-4PN12 with firmware v2.6.0. that I am trying to connect to a Kollmorgen...
2,015
Hello, 1. How do I setup IAI MCON IP address for Profinet connection to Siemens S7 CPU1511? 2. I had setup name and IP address for the MCON...
3,516
I have a Siemens 1214C PLC It only has a RJ45 Profinet(LAN) Socket on it To communicate to it I have TIA Portal V11 on a laptop How do you know...
4,362
Struggling to get a connection from a S7-1200 to a Rexroth Indradrive via profinet. Can anyone point me in the right direction. :banghead:
4,176
