GE Rx3i Serial Communications
DHoward
Jul 2012
South Carolina
25
Hi - I am looking to replace two GE 90-30 IC693CMM311 modules and will be using Rx3i system with a IC695CPE310 processor. I programmed these years ago as a CCM master and the other as an SNP-x master using comreq's. They each communicate with two remote 90-30's (CCM slave and SNP slave respectively) over a cellular connection. I am having trouble finding modules to replace these without having to change everything to another protocol. Appreciate any recommendations for Master modules and maybe options on the slave PLC's (We are upgrading them to Rx3i as well). Thanks
GE RX3i CPE305 serial port configured as "RTU Slave", trying to find address info Hi guys, I'm working on a system with a GE CPE305 and the...
2,607
Hey guys, I'm working on an existing system for a client where a GE RX3i at a tank/pump station is sending data to their office HMI through a...
3,835
Hello! At first I want to ask you a question: Anybody could help me with communication by RS485 from ASCII device to Rx3i CMM004 module. I'm...
5,258
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
390
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
285
