GE VersaMax Micro Serial Port Question
DHoward
Jul 2012
South Carolina
25
I have a project where we specified a UDR003 Micro with an analog expansion unit. The RS-232 port was intended to communicate to a wireless router / modem to enable responses to polls from a SCADA system. The customer then wants to add a simple HMI for local viewing of a few variables. Is there an available port splitter (I used one once with a AB 1200 Micro) or a serial expansion unit. Trying to keep the cost down. Appreciate any input
Thanks in advance
If you have not yet purchased the HMI, Red Lion HMIs and Weintek/Maple Systems/KEP/Nematron HMIs can read in from the RS232 and send out RS232 on a second included serial port or Ethernet Modbus to act as a gateway. A small Weintek (4.3") goes for as little as $350 including shipping, if you shop around. Both the Red Lion and Weintek include the GE drivers for free. That Versamax Micro RS232 is willy sloowwww, IMHO.
Thanks in advance
A better choice for the PLC is the IC200UDR020 it has 20 I/O instead of 14 I/O and an option to add a second port, either RS-232, RS-485, USB or Ethernet. It costs about $30 more plus the optional second port which will add about $140 more.
I'm trying to devise a serial communications heartbeat for a GE Versamax micro IC200UAL006. Is there some internal system bit that I can examine...
2,677
Hello I need to connect to a GE versamax Micro IC200UDD120 through RS-232 serial port 1 (RJ45) to program it. Does anyone knows the cable pinout...
7,215
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
394
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
433
Can anyone help me getting this comms connection set up? I am using Port 2 on the Versamax ICU200UDR005-DK, set in SNP with port settings Baud...
1,552
