GE90-70 to wonderware with redlion
voodoo
Jan 2011
ca
Hello all, I want to use Redlion (Crimson 2 or 3) as a protocol converter between a GE90-70 SNP to talk to Wonderware Intouch 10.1. I set up the comms in the redlion for SNP master and the ethernet port (this maybe wrong) as TCP/IP active with my computers IP address. But I don't know what DAserver to use in Wonderware.
Anyone gone through this before? thanks in advance.
I can using CCM or SNP with one computer but the other computer is too far away for RS232 so i want to use ethernet then i can put them all together. I wanted to use an ethernet card for the 90-70 but our local rep says that the 90-70 is too old. Have you ever heard that before?
I have seen ethernet cards for a 90/70 but i guess it depends on your cpu type. It will be lots of $$$ so maybe the redlion is a cheaper option anyway and you may gain other uses for the redlion.. is it a datastation your considering or a full HMI
Hello,
If you choose the TCP/IP active driver this will require you to create programs in the DSP to read/write the raw ASCII data. A better option would be Modbus TCP if your wonderware supports it.
Jeremy
It is always more efficient to communicate serially with a GEIP 90-70 or 90-30 using SNP or SNPx, when you can, as this is its native language. On Ethernet it is SRTP.
So to start off: I have no experience with PLC's, but I'm good at figuring stuff out, but I need some help to know if my PLC is just dead in the...
118
Hi All, I recently had an opportunity to visit a plant that was running GE90-70 redundant PLCs with Genius RIOs communication to CImiplicity...
2,300
Dear ALL I have a problem! Could i get CPU Fault Table and IO Fault Table information by the NI OPC server? Or use VB.net? Thanks
1,582
Mundane, But with four out of five cards having broken "hanger clips" (if that is the correct term) I'm just wondering if I might gain from...
1,922
Hi All, I need to dispaly an alarm whenever communication link between Simatic multipanel HMI and GE90-30 PLC is failed. There is a system...
5,539
