Don't let my update to the original problem interrupt an excellent discussion.
Today, after looking at the painfully obvious root cause of the motor mismatch, we are going to try a supposedly simpler mechanical avoidance of the correct fix.
This machine is an inclined twin screw auger (2 augers, one mostly shared trough) delivering ground (chopped) meat toward a large (10,000 lb ) blender at a pretty quick rate (~30-40 pounds per second until approaching overload via devicenet PF700 in sensorless vector mode) .
One of the screws is backwards. LEt me emphasize that...It has two left feet...
They both drive the same direction unlike any other twin screw auger I have seen. It is long, has a large diameter core and pushing meat uphill at about 30 degree incline. All the meat ends up on the south auger. The two screws are mounted in a more or less common trough with independent drve trains.
All of this is from memory, and I didn't measure anything or open the mechanical drawings yet, but the directors' solution is to (rather than buy a new motor and adapter or a counter closkwise screw) weld a divider between the augers to make them independent, hope we can meter the meat in more evenly and keep t that way.
It will probably work. I would just gritch to the manufacturer of the conveyor and insist that they fix their mechanical error or make it cheap...buy the right screw and be done with it, but I have not attained complete control of these simple, obvious decisions.
I got the data from the gearbox and researched it. It's a Sew Euridrive gearmotor, but I havent ID'd the ratio yet. I could fix the problem with a new gearmotor, possibly just a new motor, better yet, an adapter plate to a NEMA motor and a smooth stainless Sterling motor, VFD rated 10HP If the south screw fills up the meat will gradully fill up the north side toward the top like it does now only we could take out the "fault avoidance production restriction logic"...
But, that would make us right and them wrong...I shake my head...
What could be simpler to pull off in a few hours...they think they can weld in a piece of metal on a weekend and put the screws back in, cheaper than bolting on a new drivetrain? They never seem to guesstimate labor even close on these jobs, so I can expect we'll do that in-house too.
Tonight I am watching the free UFC and listening to the Thunder as they swept the Mavs, but in the a.m. after I upgrade a 75HP soft starter that blew up Friday night, I will try to post the details...I am, getting quotes for the adapter, ten horse Sterling option Monday too. Surely they will listen to common $ense this time...
dahnuguy; said:
If you want to use less current, slow down. If you can't slow down, pick the components that best work at that speed and power draw.
For simplification, I have ignored the possibility of using less power due to changes in efficiency.
Can't slow down...being the "middle man" between two other conveyors, slowing down will increase the product load at any given time. I think they sped up to avoid faults in the first place (I think this screw was installed in '05), as well as to decrease transfer times. I am going to discuss with my counterpart, slowing down to 90, then 85 , then to 80Hz while trending current and power for a few hours. I am sure he has already tried that though...
