Generate list of PDFs for PanelView FoxitReader
Valley Ind
May 2013
Columbiana, Ohio
38
I have gotten the Program Launcher to work so I can launch FoxitReader and display PDF files.
The PDF files are located on Storage Card2, there are about 15 PDF files total.
Right now I have a button that triggers the Program Launcher to display a PDF file whose filename is hard coded as string data in a HMI Tag.
Using this method I would need a separate button and a separate Tag for each PDF file.
Is there a way to open a File List Box and have all the PDFs listed there so a uses can select a PDF file from the list which will then write the PDF's name to the Tag?
Thanks in advance.
Hello Friends, I am looking for a way to take my PID Output( it is the result of my PI Algorithm in Real format) and generate a PWM Signal in...
2,560
Does anyone know a way to dynamically generate a 2D barcode on a PanelView screen? An Activex Control maybe? If such a method is out there, it...
3,009
Hi, I am trying to generate source file of OB1 including all dependent blocks. But i am getting a message which says-->>one or more blocks...
1,262
Hello Everyone, I would like to know where to start when designing a HMI+PLC Allen Bradley based, that complies with CFR 21 PART 11, ALCOA...
2,919
Hello, in iFix I want to do a boolean calculation with two values, and generate an alarm if the result is true. The calculation in my BL block...
2,194
