generating I/O drawings
jamlmath
Jun 2007
hollywood
I have been tasked with finding a program capable of creating an I/O drawing for our(boss and myself) various projects. Doing a bit of research I've found that AutoCAD Electrical is capable of importing spreadsheets and creating I/O drawings for projects. Is this the best we can achieve, or does anyone know of other helpful programs that can create drawings from the project files or some exportable format of them?
-We typically use RSLogix5/5000 for all projects
Thanks in advance!
actually it seems i can export projects to .csv and then use autocad to make the drawing, so i will download a trial and test it. any further advice or suggestions would still be very much appreciated :)
As an ACADE user that has used the spreadsheet inport to parametrically create drawings, I can tell you that that best is quite a bit of really good stuff. ACADE can also import descriptions from RSLogix, but since RSLogix doesn't describe the actual device connected to it along with all intermeidate terminals, etc, you are better off to use the Excel import.
You could convert everything to Modicon and use Proworx, which will generate an actual DXF file for every module for you, and if you've taken the time to add the symbol associations into Proworx, it will stick them in as well. But it still leaves out details such as terminals, wire numbers, etc. So I still think the ACADE Excel import is ahead.
Hi! First time posting here. New to AB PLC family and working on this new project. Using Micro850 PLC and PV800 HMI and CCW. The project is to...
1,443
Im using studio 5000, in my software, Im using E300 overload protection relay to control a motor. Studio 5000 Version 32.12 E300 Version 7...
2,881
Hi, I have a new PCS7 project with a 6ES7 417-4XT07-0AB0 CPU. When compiling the System/module CFCs are generated from the hardware. But in my...
1,266
Hello Guys, I spent some time searching the web to learn how to generate the report (to be printed out or to be saved as pdf file) which would...
1,219
Hey all, I'm trying to use a OB16IEF to generate a 24V PWM signal. According to the manual all i have to do is set... Local:#:C.Pt[#].PWMEnable...
2,940
