PCS7 generating the @ CFCs in PCS7 v9.0 SP2
userxyz
May 2002
any
2,768
I have a new PCS7 project with a 6ES7 417-4XT07-0AB0 CPU. When compiling the System/module CFCs are generated from the hardware. But in my test set-up I have an older 6ES7 417-4XT05-0AB0 CPU. When I replace my 4XT07 with the 4XT05 and deleting the system CFC's, the generating fails. It compiles and download to the CPU, the CPU rund the program, but the @ CFCs are not generated. With the 4XT07 no problem...
We use the diagnostic blocks for connecting to the MODE of our channel blocks.
What could be the cause and what can we do about this ?
Thanks,
regards,
C
Found the issue,
On a 6ES7 417-4XT05-0AB0 FW 5.2 the problem occurs, but FW5.3 the @ CFCs are generated. I have to upgrade my CPU to the latest FW.
Does anyone have an example project of the cm ptp ET200 SP HA with 410-5H DCS (PCs7 9.1 SP1) for MODBUS MASTER/SLAVE communication ?
132
Hello, Is there a sequence when installing both TIA Portal and PCS7 in the same PC? First TIA and then PCS7 or viceversa? Thanks in advance.
484
Hello, I'm currently working on a project involving both PCS7 (v9.1 sp2 upd1) and a Panel Comfort system. This necessitates the use of TIA Portal...
805
I'm coming from a background of PLC ladderlogic/rockwell products. I am new to blocks. Can you point me in right right direction? What I would...
1,562
Hello everyone, i would like to read in pcs7 v8.2 the actual day of the month(ex 1 or 25 of the month) i used as attached read_CLK AND DT_DATE but...
1,935
