Robert Carlsson
I've written a function block that calls several SFBs that I want to be able to export and import and compile. My question is how I do this the easiest way? Right now I simply call the SFBs, and have created instance DBs.
But if I remove the instance DBs and the FB, and try to compile the source, the compiler says the instance DBs are missing. This is of course true, but is it possible to have Step7 automatically create the instance DBs, or is it possible to include the called SFBs instance DBs in the FBs instance DB?
