Get CPU status via OPC
Hello Pavel.
What HMI program are you using ?
The bad news is that it is not directly available.
The good news is that you can derive the status by means of a script in the HMI.
Follow the link in the last post.
http://www.plctalk.net/qanda/showthread.php?t=20077
The method is to send the HMI clock to the PLC, and then let the PLC send it back to the HMI. The HMI then calculates an event trigger time by means of the returned time value.
Normally, when everything is OK, the trigger time is continously moved forward so the event does not trigger.
If the CPU is offline or in STOP mode, the value does not update and the event triggers.
The example is for a normal connection with the direct drivers, but I cannot see why it shouldn't work with OPC.
Im use such as OPC client czech scada system Reliance. I understand you, but your mothod is difficult. Im used OPC server other production too, and there I definition only one byte variable as system status value 0= Stop, 1= starting, 2= running. It is rationally.
Good afternoon, I have a Simatic S5 / S5-135U with three CPU 928B. The PLC is not operating due to a BASP error. On two of the CPU boards only...
1,058
Hello everyone, I have 8xS71200 cpu fitted profinet with Wincc RT on pc station .I use tia portla v13 sp1 and i want to check and show current...
9,564
Hi Everyone, I want to know how i show the cpu status in wincc flexible runtime. i am using the cpu 325-2dp with profibus network. when anyone...
2,102
Hi All. I'm creating several diagnostic screens for the maintenance personnel, displaying the I/O status. Do you know if it's possible to get...
3,707
Hi, does anyone knows what is the problem on an S7-400 cpu in case all the leds are constantly on (not blinking, I think in this case it that...
7,217
