Get V32 license from V31 Central Managment Server?
theColonel26
Feb 2014
West Michigan
786
So I have a customer that lets their IT run rampant and requires us to use a Jump server. The problem is that our PLC project is V32 and their Standard Version is 31 at the moment. Can I get a floating license for V32 from a V31 server?
I am pretty sure you can. I believe our license server has a RSLogix 5000 license version 26 and that single license supports versions from 13 through 32. I just created a new project using version 32 and it didn't bark at me.
I agree that you can
The issue that I ran into with V27.00 to V32.03 ... the FT License manager is much newer on V32 and won't talk to the FT License manager on our older license server. V31 to V32 should be OK.
BTW - A jump server is just a small part of defense in depth. The combo that I find most annoying is: assigning all unused ports to an unused VLAN, and disabling all of the unused ports on the switches. So trying to troubleshoot a faulty cat6 cable requires getting the switch config changed and a VLAN enabled :(
ie - be happy it's only a jump server.
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
217
Got a repaired laptop back from warranty and loaded it up with all my software, unfortunately with my version V32.03 Studio 5000 I cannot change...
216
During the process of installing Studio 5000 Mini Edition to my new machine at work, it seems as though some things like RSLinx Classic and the...
628
I am looking to upgrade a CompactLogix on V18 to an L83E on V32 which is currently using a Beijer E1151. Does anyone know if the E1151 is directly...
666
Hi, I am having issues with Studio 5000 v32.02 and connecting to a 523 PowerFlex drive via Ethernet. My network consists of a 5380 CompactLogix...
1,863
