Cable received. Thanks.
I've found STEP 7-Micro/WIN V4.0.9.25 on an old laptop, so I guess I'm good to go.
GiT, can you give me a little guidance, please? I've read the info on the driver CD supplied and looked at a couple of videos but I'm still confused. The cable I received is marked USB/PPIM+, so it appears to be the correct one. When I plug it in, the only place it appears in Device Manager (Win 7) is Human Interface Devices (two spots, one is HID-compliant device and the other is USB Input Device). I believe that it should appear in the list of drivers in the Set PG/PC Interface dialog in MicroWIN but the only ones I have (apart from network, PLCSIM & VMware ones) are:
PC internal local.1
PC/PPI cable.PPI.1
Serial cable.PPI.1
TS Adapter
TS Adapter IE
USB.S7USB.1
Which one should I use or, if it isn't one of these, do you know how I install it?
