Ok, Well the station number is 1. Is this what you mean? I then went on to the CIT device, and set its Modbus Slave ID to 2. Double checked the baud (set it to the slowest 2400), no parity and 1 stop bit. Then went the to the ladder logic mrx command and set the slave id to 2.
I then tried removing the number of bytes read to 2 just to get the first sensor.
Still nothing. SP116 states are toggled, but only the 1st bit is set on registers V400 and V2000. (Of course I'm checking these values via XRef once the program stops - is this wrong? )
If you look at the CIT manual, there are some debugging function codes, but these are 8 for Diagnostics, and 11 for to report slave ID - both of which can't be used when using MRX.
