Getting the master disk over to flash drive to Install RSlogic
To answer your question, yes there is.
Next question, "How do I do it?". You need to download EVMOVECF from Rockwell's website, and the flash drive must be formatted using FAT32.
USB Floppy Drives are on the shelf at Office Depot, Frys, etc. About $30.00 to $40.00 bucks. I chose one that worked directly with XP without needing a driver loaded (don't remember the name, but it wasn't Sony). That way I can loan it to friends without having to dig around for the stupid CD that came with it.
Alternate method for networked computers:
If you have a networked desktop with a floppy drive, share the drive. Then with your laptop connected to the network go to my network places, navigate to the computer with the shared floppy, select the shared floppy, and then pick tools->map network drive and assign a drive letter of your choice. There is probably no need to select "reconnect at login". With the master disk in the floppy drive of the desktop then you can move the activation to the laptop hard disk using the standard evmove utility by selecting the mapped drive letter.
Hi Step 7 experts!🍻 I have connected a master (314C-2DP) and a Slave (same CPU) with HMI MP277 thro' PROFIBUS. Both Master and slave can...
2,730
The application was working in Twincat 4022.16 Used VM for offline. recently changed the laptop and the getting the error with Message as below...
65
We are using wincc scada WinCC system software V7.5 SP2 , connected to few plc . Past 3 weeks we getting this alarm continously when we checked...
92
I am very, very new to PLCs. I only have experience with Picos, but I knew enough to save this from the dumpster. Apparently, everything on it is...
632
Hi, I tried today to get RD3A and WR3A instructions to work on the PLC and it didn't work, but it worked in simulation. I followed the clone...
18
1,467
