TConnolly
cntrlfrk said:I've used ground fault detection on switchgear, which usually results in a 'needle in a haystack' search for a bad motor. Is there a better way to narrow down where the fault is?
For motors use an Earth Leakage Relay. This is different from a GFI.
http://library.abb.com/GLOBAL/SCOT/scot260.nsf/VerityDisplay/D8A3B255544D297985257099004A46E4/$File/CM-IWN-AC.pdf
You wire the relay into your starter control cicruit or into a shunt trip breaker. They have an adjustable trip point from 1K to 110K ohms.
