Go online with powerflex 40 on profibus
Jay69
Aug 2009
Canada
I am new to profibus. I am wondering if i can go online with the profibus just like devicenet and save the drive parameter using drive executive?
I definitely don't think so. Profibus does not share the CIP protocol that is the core of the RA networks, and is the reason that RSLinx can hop from EtherNet/IP to ControlNet to DeviceNet.
I'm curious about why you chose Profibus instead of EtherNet/IP to connect to these drives; are there Profibus-only devices is the system as well ?
HI
I agree with Ken. I have not used this card but I have used the Control logix version and you could not drill down to the drive.
I Also have the same question why Profibus when you have a ethernet port that
you could use to connect to the drives.
Donnchadh
What is the proper method for adding more datalinks to a VFD that is already online? When you go into the module properties in Logix, the...
2,359
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
62
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but...
237
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
394
Got a VIPA 315-2AG23 that i try to go online with but can't seem to make it work through a network. I can go online if i'm plugged directly in the...
277
