Going from Flex Logix controller to a Control Logix
mattjsayers
Jul 2011
Maryland
I'm pulling out a Flex Logix controller and updating to a control logix 1756-L72. My question is will that just straight swap out? and do I need to change my programming to talk to the existing I/O that is staying? (I am just changing out the controller and adding two Ethernet cards 1756-ENT2T's for PLC to PLC and HMI communications.
Welcome to the Forum !
If you had local 1794 FLEX blocks, they'll need to be reconfigured as I/O blocks connected to a remote 1794-AENT(R).
When you change the controller type, all the remote I/O modules get deleted and you have to add them back under a new 1756-ENxT module in the I/O tree.
I do this by opening two sessions of RSLogix 5000 and copy-pasting the I/O module definitions between the two. It's a little tedious, but much faster than typing in all the configurations by hand.
Good Evening , We have a number of Powerflex 525 Drives . I took notice for years elsewhere and our plant , that our Powerflex 525 drive...
642
Software Ver. 22.00.00, After the 1st time of being true the EQL. instruction is still allowing the rung to be true even though the inputs are...
228
Hello all, I am brand new here :cool:. I'm limited in my controls knowledge but always trying to learn more. I recently started working at a...
336
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
396
We have a 4 wire 0-10V analog OPT2012 (Time of flight distance laser) from Wenglor that we're experimenting with. We are able to teach the laser...
552
