going online with a slc 5/02
valspar
May 2014
texas
Its been a long time and I must be forgetting something basic.
I have a 5/02 with a fault.
I have a pcmk card in my laptop and a cable from it to the 5/02. I think I have tried every configeration to get online but cannot. I even pulled off and went and tried a different 5/02 process with no luck.
I have read forums in here for an hour and tried what I could find.
pcmk dh-485, rslinx, station numbe 0, speet 19.2, max station 31
I am out on the line right now.
Welcome to the Forum !
I don't know what else to tell you, though: all your settings look correct for connecting to an SLC-5/02 with a 1784-PCMK card and 1784-PCM2 cable with RSLinx Classic software.
99% of DH485 networks run at 19200 baud, but you can always check 9600 baud too.
And I've never seen a controller set for Node 0, but you might try a different Node number for your RSLinx station.
I tried the different baud rate, a differnt cable, and changing the node......... nothing helps............maybe I have a bad card???
Thanks for your reply.
In Linx does the driver for the PCMK card (AB-KT1 as default) show running? If it says port conflict or Error then it wont work. As above maybe you have a PLC at node 0 so setting to a higher number might work.
Still battleing this today.............. Thanks for the help........ have someone else with a laptop and pcmk card comeing out to try to connect.............. my computer shows no conflicts and is receiving and sending packets to and from the pcmk card........... I guess the card could still be not operating and / or both my cables are bad.
Thanks for everyones support.
Hello Everyone, I'm a pretty green PLC tech and I need help logging on to some SLC 5/04 PLCs. I have a 1747-UIC and 1747-CP3 cables and I'm using...
6,976
For some reason every time I go online with one of our SLC 5/04s It makes me upload the program even though the only differences between the...
1,588
Im trying to figure out how to go online with a slc 5/02 and a proface touch screen at the same time, I want to be able to be online while the...
2,129
Its great to be able to contribute something for once after having used the forum. ANyhow, a particular 2 * 7 rack SLC system has been a...
2,314
Hi there i am using SLC 5/03. i installed RSLINX Classic and i am running it as an application. i am using a LAptop, and i am using a USB-Serial...
2,203
