Good Hardware Alarm Notification Box
12brich
Sep 2003
CA
61
Does anyone know of any good box that can do alarm notification? It does not have to be as sophisticated like SCADAlarm or Win911, but should have 75-80% of their capabilities. I've worked with both SCADAlarm/Win911 over the years and there are a few annoying things that I don't particular care for. They have something to do with windows interface, running the same software on the SCADA PC/modem and so on...
Well, I am just simply looking for an alternative where it can interface with the SCADA box using modbus or some OPC servers. Any recommendation?
Don
You may use U.C.ME-OPC alarm notification software. It is easy to use and offers good functionality. It uses OPC (or DDE) to connect to any OPC server or SCADA/HMI software that supports OPC or DDE server functionality.
Alerts may be sent via: Email, SMS, Phone(Voice), Fax, Multimedia and WAP. It may also be used to analyze your alarms and understand the root cause of the alarms.
See www.controlsee.com . A fully functional evaluation version can be downloaded.
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
41
I have an 1769-L16ER that I use to test code and I just found that I can't create MSG tags at the local program scope - they have to be done at...
205
Hi all, This is going to be a long post apologies. I'm also a complete beginner to the world of PLCs. I'm currently working on my first ever...
482
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
165
hello, I am using Beckhoff with TwinCAT3 and when I change or add some new hardware or for any reason, there is a mismatch in the real hardware vs...
136
