Got programmer..need PLC!
JetSam
Feb 2007
UK
Hi! I'm rather new here, but I wondered if someone out there would be able to offer me some advice.
I recently got hold of a both a:
Toshiba EX Series HP100 Handy Programmer Part No. EX25UHP*100
Mitsubishi GP-20 Programming Unit Part No. GP-20F-E
The project I am working on requires a very basic PLC unit with about 10 I/O.
Do you know what type or types of PLC the controllers can be used with?
Would the Toshiba Programmer work with a Toshiba EX20?
Thanks,
Sam
Sam,
I have some bad news. The handheld programmers (that I have seen) are very difficult to use and limited in display area. You would be much happier to get a cheap PLC that has free software that will run on your desktop computer. The Allen-Bradley Micrologix has a free version of the RSLogix programming software that will do exactly 10 I/O.
As a beginner, do you also want the headache that comes from using a small 2-line or 4-line display screen? I sure would not! I want at least a 17-inch monitor, so that I can see as much of the program as possible at one view.
Also, there are many other small, economical brands, such as Enteron, Omron ZEN, Automation Direct DL-05, with free or low-cost programming software. Only use the Toshiba if you have some other reason to use it, such as good local support, or a good deal on a Toshiba PLC, or that you already know how to program a Toshiba. Otherwise, start shopping!
Hi, thanks for you reply, I had forgotten about this thread! Since then I have got hold of an EX100 PLC which will suit the application fine. I am fairly familiar with Toshiba PLC's as i worked with some old EX20's for a year using just a hand held programmer.
Cheers,
Sam
Do any of you have any former experience with the CQM1-CPU11 [CPM2A] Item Code Status Details 01 - 0x00FA - Fatal - IO Unit Over Error 02 -...
2,993
269
Hello everyone, its been 8 years since I frequented this forum. I had a lifetime membership with my old profile, but could not remember my...
17
954
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
385
