mtomlinson
Hello,
I'm not sure if this kind of troubleshooting post is allowed here, but I'm at a loss.
I'm trying to configure a Grundfoss CIM 500 ethernet/IP communication module for a Grundfos Pump. For this particular module you need to give the module a webserver IP and 'pump' IP.
I was able to set a webserver IP when the rotary switch was in position 0 (profinet). When this gets switched to position 3 (EIP) I'm unable to connect to the modules webserver and get intermittent pings back from it. You have to have the switch in position 3 to set the pumps IP address. Does anyone have experience with this module and know how I can get it up and running?
