gsd-file CP541
Greet
Aug 2003
Mol
58
I'm trying to connect one S5 and one S7 -PLC via the CP541-communication-card (to get some info of the S5 on the WINCC-station).
But I can't seem to find the CP541 in my catalog. I also don't find a gsd-file for it. Can someone help me?
Thanx,
Greet
As far as I can find out a CP541x is a profibus card for a PC ..
If you want to connect PLC and PC in an S7 project you have to add an HMI station to your project and then install a CP5411 or 5412 card
Greetings
Eric Buysse
The CP5411 or CP5412 card is an S7-card.
The CP541 is an S5-communication-card(with profibus-port, so that I can connect in my Profibus-circuit).
Greetings
OK, after two days searching on the net, I found the correct gsd-file!
But I have another question about this CP541. In my S5-PLC I have to write the correct parameters in DB1 (SL1). Can someone tell me what the parameter PGN means? (PGN = programmer bus number). I still want to use the sinec L1 for my PG if there is a problem in the production. So what is the BUS-number of my PG-connection?
Greetings
Did anyone please help me with gsd file of krones heating module(make Siemens)
92
102
Hi guys, I need a GSD file for the following sinamics drive (S120). IO Device SINAMICS S120 CU320-2 PN V4.4 PN-V2.2 with DriveES/SIMOTION...
1,477
I have a device that is connected via modbus to a modbus-profinet converter, and then to a scalance switch. I have no idea how to establish...
1,810
PLC in the project that I am currently working on has following GSD file but I cant find it anywhere online. My PLC is ET200S and its CPU is...
2,104
