GuardLogix Fault
derrickjp7
Apr 2019
Minneapolis, MN
Hey everyone,
I've been tasked with figuring out how to utilize a GuardLogix with our machines at work. I've been going off of a very simple program scavenged from another. It basically consists of two channels going to a DSC instruction, to an ESTOP instruction and finally a CROUT instruction. The problem I'm having is the CROUT keeps faulting out with a "16#5003 20483 Feedback 1 and Feedback 2 turned ON (1) unexpectedly."
I did a trend on these outputs and I'm not seeing anything happen. Nor triggering the reset makes it go away. Any suggestions what might be causing this?
Thanks everyone!
So a feedback fault is saying that the output feedback is coming on when it should not. Often the cause is having the wrong type of feedback selected. Generally this is set to negative so that when the CROUT is TRUE the feedback should be off and when the CROUT is false the feedback should be on.
I had a comms fault between my VFD and Controller (5069-L320ERS2) that started about a month ago and happened maybe once a day to now where it...
292
Hey everyone, I have a problem that is the CROUT keeps faulting out with a "16#5003 20483 Feedback 1 and Feedback 2 turned ON (1) unexpectedly."...
1,313
Hi all, we have a 1768 compactlogix 5345s safety controller firmware 20.14. it is randomly giving a major fault and a minor fault. the minor...
1,418
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
115
I just finished a project that was using a CompactLogix(5069-L310ER2)and the project now requires a GuardLogix(5069-L310ERS2). I will be...
629
