GX developer Z0 and RxxxZ0 registers
dmta
Sep 2015
Tyhk
Dear all,
I have this sort of registers being accessed in a PLC ladder diagram that I am looking at these days.
M8000
-----| |------[MOV R900Z0 D400]
M8000
-----| |-------[MOV D301 Z0]
What are these R900Z0 and Z0 registers? Where can I find the section about these in the fx-3u programming manual? It seems Z is used for some pointer operation but that's all I could find.
Best regards.
dmta
in GX Developer Z & V are indexes and work as follows
the value of an index is moved in to the index register
[MOV D1 Z1],
this moves the value of D1 into Z1
if D1 is 10 then Z1 will be 10
The register can then be used
[MOV D900Z1 D400]
this means Move the value register D900 + Z1 to D400, so if Z1 = 10 then Move the value of D910 to D400.
So the index changes the register to be read, not the value in it.
M8000
This means move the value in R900 into D400
But the Z0 has a separate value which is decided by the MOV D301 instruction
For instance, if D301 was 10, then 10 is moved into Z0
so now
M8000
means MOVe R900+10 which is now the value in R910 into D400
dear all,
Thank you for the quick response... the Z is used so that by changing the index you can decide which register you are accessing.
Can you also tell me what type of register "R" refers to?
Best regards :)
R registers are just normal registers (Like D registers)
The only difference I know of is that they can't be retained - more like working registers.
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
53
Well, I've decided to start a new project, and like all projects, it has already gone horribly wrong. I purchased a PLC device (supposedly a...
113
Does anybody have any samples of how to "Create and Use" UDT's in CCW Developer Edition? (I am using v22) I can't find any information from...
314
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
383
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,172
