GX Works 2 daily maintenance
swedeleaner
Dec 2013
Göteborg
144
Hey guys!
Just got assigned to a new project involving a Mitsubishi FX3G, programmed in GX Works 2.
I´m trying to do a maintenance cycle that should be executed at the same time every day or week. I´ve looked at the function HOUR i´m not sure that is what im lookin for.
Is there a function that can call a specific time every day, lets say 2:00 every night?
Or is there any other good way to execute tasks at a specific time?
Hey guys!
I haven't worked with the FX3G, but the FX3U has a real time clock you can reference. Once the RTC is set, simply compare the special register containing the hour with a constant of 2 to trigger your function.
You will have to check the manual to see if your PLC has a RTC.
-Dave
Are you using a HMI on this project? Personally I find that the Mitsubishi FX RTC is not as accurate as most HMI's are. Many HMI's have this function build in (set a flag in the PLC at a particular time). They usually also automatically adjust for Daylight Saving Time - just a thought
Thanks a bunch Dave!!!
The PLC have a real time clock, and found the registers I were looking for.
Just a question, declaring a constant in GX works is done by assigning "K2"?
It seemed to work, but just want to be sure it´s correct.
twocozz, i have no HMI connected to this PLC.
Sorry for the late reply!
No problem, and yes a k in front of a value is a constant.
-Dave
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
74
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
347
PLC: Fx5u CPU As Per manual High Speed Input Module can add from Navigation window  [Parameter]  [Module Information]  Right-click  [Add New...
106
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
118
Hi Guys, I want to connect my 1769-L36ERM to a different network domain, is it possible to do it using only the dual ports in the Controller? Or...
232
