GX Works Compile
Asaddoris
May 2018
Georgia
19
Hello everyone,
I got another question for our Mitsubishi experts on here.
I have a PLC file that was already written before me, I have made changes to this file and haven't had any issues.
I needed to add another couple lines of logic to my program and when I try and compile I get 0 errors, but all the files on the left turn red and will not compile.
In an attempt to troubleshoot, thinking it was something in my logic, I individually copied and pasted to a copy of the original file before editing. Each copy and paste I compile.
I finally get to the line that is causing problems, but it has nothing to do with the logic, but rather seems like I'm out of memory.
Now when I do confirm memory check it will not allow me to with the program not being compiled.
If I delete the line of logic and compile and check it appears I have more than enough for the changes I want to make. I have attached the memory check screen shot.
I am at a loss at this due to it not giving any errors or warnings for the reason it won't compile. Hope this makes sense to someone out there.
Ok I figured it out!
If you go to Tools-Options-Compile-Output Results
there is a stop build after xxx amount of errors or warnings. This was set at a low value and due to warnings in the compiler it would stop build after I exceeded this amount.
Hope this helps the next person.
Hi, I am using GxWorks2 for PLC programming and configuration. I have 47 routines in my Program. After build I am getting following error. Please...
3,836
3,108
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
78
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
348
PLC: Fx5u CPU As Per manual High Speed Input Module can add from Navigation window  [Parameter]  [Module Information]  Right-click  [Add New...
106
