Half Bridge vs Full Bridge Load Cells
Tim Ganz
Dec 2010
Dallas, Texas
692
I am trying to determine which load cells are best for tension measurement of material going on a center winder with the laod cells being mounted to one of the S wrap rolls before the winder.
We have some that are half bridge type laod cells and the 2 of them are wired in series to the amplifier that gives our 0-10 volt signal and we also have some that are full bridge that are wired parallel to the amplifier.
What is the advantages and disadvantages of both. All I can find is vendor ionfo that says mine is best and so fourth. Wanted to get some opinions from people that have used both.
I am just trying to get us standard on one or the other as we have a lot of these in our building.
Tim,
i googled half wave bridge load cells and found this information.
http://www.sensorland.com/HowPage002.html
this is a how it works type site.
i always used full bridge systems so i could see the tension and compression. if it started to drift, the output would tell you. if it drifts alot, load cell going bad.
omega and sensotec had at one time lots of document on the subject on the web.
hope this helps,
james
I'm having some trouble running a test application in factorytalk studio. I'm using FT12, my screen resolution is set to 1920x1080, and when i try...
1,161
Good Morning Folks, I'm having an issue with a triconex tri-gp. After 24-48 hours of runtime, I lose my SCADA connection to it, which I correct...
1,528
I have a 10k load cell with signal conditioner that I need to read on a PLC. I can buy a Micrologix that only go up to 12 bit (4095). So the...
2,880
Hi, carrying on from my SLC5/04ML1000 half duplex dilemma thread http://www.plctalk.net/qanda/showthread.php?t=120254 were l show how l have...
20
4,806
Hi all, after much aggravation trying to get my SLC5/04 to talk half duplex to RSlogix so l then would be able to communicate with both RSlogix...
2,246
