Hank
hankm1
Feb 2006
Ohio
Hello,
What is the largest recommended monitor size for a PLC? Will the resolution be affected by say a 42" monitor? Which would be better: LDC or Plasma display?
It depends pretty much on what distance you're going to be working from. If you're looking at it from 10 m away then even normal VGA will be OK. On the other hand if you're going to be sitting in front of it at (approximately) the same distance as you would from a normal PC monitor, then even 1600 x 1280 isn't going to be enough and I don't think you'll find that many 42" monitors that even go up to that resolution.
As far as the LDC / Plasma equation is concerned:
Size for size Plasma is usually cheaper than LCD
The viewing angle for Plasma is usually wider than for LCD
but
Plasma uses much more power than LCD.
If you can tell us a bit more about the application, you'll get better and more precisely targeted answers.
49
10,859
I've been doing Modbus for 20 odd years but almost never do I have to use a slave simulator. Until today. I used Peak HMI's freeware RTU slave...
1,973
So I have a personal project where I want to use a photosensor relay (no/nc) as inputs on my Siemens logo. When the lights are on I want the...
2,512
Hi All, I'm curious if anyone else has had this issue. I am the site coordinator and purchase ten seats of Rockwell Software each year for our...
18
10,643
:banghead: Dear Rockwell, as we are in the final month of the year, a time that most integrators are swamped with control upgrade projects...
21
6,693
