Have anybody used the AB 1756-HYD02 Module
Coachman
Sep 2006
Maryland
97
Good Morning ,
I am starting a project that would involve the sequencing
of some Hydraulic Cylinders. I have been looking at the AB 1756-
HYD02 module. Have anybody had much success with this module. I
tried to find it at the Automation Fair and could not find it.
I would appreiate it if someone could give me some feedback. I
know Rexroth as some external units that would do the same thing.
Thanks in advance, You and your families have a Great Thanksgiving,
Your request is very vague.
HYD02 module.
People have been sequencing cylinders for years before there were motion controllers. That is a lot of PLC for just 'sequencing' cylinders. If you go to a hydraulic forum you will see there are sequence valves for sequencing actuators.
Yes, and I know others. They are relatively trouble free and work as advertised. Alan Case on this forum had done a project using HYD02s also. I know many others that have since I am involved in the saw mill industry a lot and there are basically three controllers that dominate that industry. Have you searched the forum for HYD02?
I tried to find it at the Automation Fair and could not find it.
You are right. What was Rockwell thinking?
I think I can answer your questions if I knew what they were.
I know Rexroth as some external units that would do the same thing.
Note quite. The Rexroth units don't fit in the rack and it would be a lot more difficult to 'sequence' many of them. The 1756-HYD02 and its 'siblings', the 1756-M02AE and 1756-M02AS, all work pretty much the same. They were designed so one could mix, match and coordinate different axis types and still use just one set of motion blocks. Rexroth can't do that. The HYD02 can do anything the other 'siblings' can do within the limits of the feedback devices such as synchronized motion, gearing, cam tables etc.
I can answer your questions if you can be a lot more specific and also tell us what you are trying to do. Otherwise what I say will sound like an advertisement or a manual. What ever it is you are trying to do I bet I have seen it before.
I have an application where it looks like PM-Control and PM-Quality might be exactly what I need. But...there isn't any support for these packages...
1,916
I'm just discovered these vortex coolers from Automation Direct. I've never heard of them. They cost 1/10th of an A/C unit of the same BTU rating...
8,995
I am sure there are plenty of people here that have used Watlow temperature controllers. We have a thermal chamber that we used to temperature...
3,032
New here! Has anyone used a "1747-UIC" from eBay? They look off-brand...but I just need something to use on a SLC 500 1747-L40A. I have an old...
5,335
I have a CompactLogix with a devicenet scanner connected to a Rexroth HACD card. I am unable to get it properly configured and the data mapped...
20
4,899
