HC900 Modbus TCP
_V_
Aug 2023
Portugal
31
Hey everyone, Im kinda of stuck in a situation and Im asking everyone support on this please, I truly need everyone help.
Here is the situation, I am doing a project and I need to communicate between HC900 (using the software designer software) and ABB variator ACS880, and I want to read values from the variator to the PLC and write values from the PLC to the variator.
I am reading manuals and manuals and I can't get nothing, by the way I am using fena-21 on the variator for the ehternet modbus communication.
So guys how do I read and write ? I know I have to use function block modbus tcp, put the IP of the slave (variator) and but big endian, then I use register on the read tab and what now ? what is adress(hex) ?
If you guys could help I appreciate. Thank you.
I replied to your private message with steps to take before I could help you. The process is very easy and the help system in the software is excellent. After you have done what I said, I'll be happy to follow up.
Hello, i have a curios problem in a modbus tcp reading from a client. The HC900's answer for the variable 20 (holding register 6375) is clear in...
17
3,130
I am currently working on a steam generation plant. We are using Honeywell HC900 C70 controller. There are 30+ instruments connected to E&H...
2,866
Hello everyone. Using the designer software for the HC900 had me thinking. How can I assign 1 variable so 1 single bit. Like how can I say that...
450
hi all i test the HC900 modbus (master) read function by connecting s1 port to my notebook with rs485 usb converter. in the HCD, i monitor the...
4,173
I'm upgrading an existing machine with a Honeywell HC900 controller, and I'm trying to do some data processing in the controller. I have variables...
56
