Heater current monitoring
pauly
May 2002
South Wales,U.k
244
I have to replace temperature controllers for an extruder and it is a retrofit. Each zone (there are 8 per controller, 72 loops in total) has up to 4 single phase SSR's spread across the three phases, so SSR1 is on phase L1, SSR2 is on phase L2, SSR3 is on phase L3 and SSR4 is on phase L1. This is per loop. I have a temperature controller that has heater current monitoring via CT's but this requires the heaters to be connected to the same phase.
Without being able to rewire the panel could anybody suggest a way of measuring the current across the three phases to utilize the onboard heater current monitoring?
I'm not sure I fully understand what you are after but can you just add a power meter with some split core CT's where you need to measure ?
So, if I understand you correctly the temperature controller can control 3 or 4 heaters in one go, but only one CT input.
Without running all 4 wires leading to the heater through a CT, I don't think it's possible. Even then, not really sure how it would work.
Has anyone here a lead on monitoring AC current? We are rebuilding a machine that has approx. 70 heater zones, and in the past, each has been...
28
11,785
I am charged with designing a heat control system that will replace an old system on this companies machine. It is a "Hot Wire" system that trims...
18
6,221
This is something I figured out that electrically doesn't make sense to me. An electric blanket with a single heating wire looped through it and...
1,037
Hello everyone! I'm new here and this will be my first post so hopefully I can get some help, I'm having a hard time wrapping my head making some...
4,791
Not directly PLC related, sorry, but I believe I'm ok to ask this question at this forum. I'm a Controls Engineer, programming PLCs, HMIs etc. I...
19
9,373
