Heater Rating Question
skyfox
Nov 2006
CA
279
I am in need of some help trying to figure out how the max output temperature of this heater was determined or derived by the manufacturer.
HEATER SPECS:
Heater Type: Flexible 2"x2" surface mount Silicon heater. (for Tanks/Pipes/etc.)
Supply Voltage = 24VDC
Power = 10Watts
Temperature rating: to 300 Deg. F
Does it mean it can operate/withstand up to 300 F or it can heat-up a surface (given the right size/weight of the material it is attached to) up to 300 F?
Cheers.
Thanks jraef,
Appreciate the link. I specially like the part where you said "but it’s safe to say “not much”. I am trying to use this heat wrap as a heat trace to keep a small SS valve about 3" tall with a 1.5" diameter used in a sub zero process application (-110 deg. C) from freezing up. Heat trace or a heater wrap is not usable in my app where an operator has to physically remove the device containing this valve on a regular basis as in 3 to 4 times a day after it has reached ambient temperature upon completing its process sequence.
Thanks again for you help.
Best Regards.
This is something I figured out that electrically doesn't make sense to me. An electric blanket with a single heating wire looped through it and...
1,040
Hello everyone! I'm new here and this will be my first post so hopefully I can get some help, I'm having a hard time wrapping my head making some...
4,793
Not directly PLC related, sorry, but I believe I'm ok to ask this question at this forum. I'm a Controls Engineer, programming PLCs, HMIs etc. I...
19
9,374
Has anyone here a lead on monitoring AC current? We are rebuilding a machine that has approx. 70 heater zones, and in the past, each has been...
28
11,788
I input error into PID as a percent and limit the control variable +/- 100. i.e. rError[0] := (rTarget-rPV)/(rSP-rPVInit)*100 When calculating...
24
6,615
