Help can't see right side of LAD2
Robastala
Feb 2023
Texas
I'm a student in college and we are using LogixPro this semester. I have encountered a problem where I can't see the right side of the editor. To be more precise I can not edit the output energize function as it is invisible.
The line is blue for about 3/4 of the screen and disappears without showing the right side of the ladder. I have tried looking for a fix but I have been unsuccessful. We are accessing the program through our schools citrix workspace.
If the resolution of the Virtual machine running the software does not match the resolution of the computer you are using to access the software, there should be a slider on the bottom edge of the screen that lets you pan back and forth. If that is the case, there should also be a slider on the right side that lets you pan up and down.
I suggest that you pan to the top right, select the window resizing, and size the window so that it fits the computer you are using
I've attached pics, below. I'm in the field right now an am trying to communicate to the Micrologix 1500 through the 1761-NET-AIC (Ugh!) to...
1,960
Hey guys, I'm programming this stepper motor to go back and forth at two set angles. After programming, I realized that my program only works when...
2,320
I am having a bit of trouble with mechanical engineers and safety. They are doing things like saying "a light curtain is being used as a "go...
5,378
Hello I am building a machine and i would like to get some suggestions about the right plc to choose for my application. My application: I need...
6,690
Hello all, this is Ramana from Hyderabad, India. i am new member to this forum.. i need your suggestions for my project.. Data is i have 60...
1,575
